2023-10-02 08:08 AM
For some reasons, I have duplicated a drawing in the same layout. The idea is to show different details on them using separated layer combinations but each time I change the setting of one drawing, it automatically affects the other. It is possible to unlink both drawings or make them independent?
Thanks
Solved! Go to Solution.
2023-10-03 02:55 AM
2023-10-02 08:50 AM
Do you have each drawing on the layout sheet linked to a separate saved view? Or are they linked to the same saved view?
2023-10-02 08:59 AM
The drawings are linked to the same saved view.
2023-10-02 09:25 AM
There is your problem.
You need to save separate views and each can have different settings (i.e. different layer combination).
Then place each view on the layout.
2023-10-03 02:55 AM
Thanks for your help.
