ā2021-11-18 08:25 AM
Is there a way to load multiple surfaces from a library (in our case our bim cloud library)?
We usually would go to the surfaces setting and click new> new from catalog>bim cloud library...
but this only allows us to load 1 surface each time.
ā2021-11-18 10:06 AM
If they are already loaded into another project, could you just use the Attribute Manager? Have not used BIM Cloud before...
ā2021-11-18 10:28 AM
This is not 'loading' a surface.
They are already loaded in your library - otherwise they would not be there for you to add.
You are creating new surface attributes, and as all of the settings for each new surface is different, this is probably why you are allowed only to do one at a time.
Once created, they are then an attribute which you can export/import to any file - more than one at a time.
ā2021-11-18 11:46 PM
oh right.. I meant creating surfaces. Just wanted to see if there's a way to get all the surfaces that are loaded into the library into the surfaces instead of doing it one at a time.
