MEP Labeling
Hello all,
One quick question. Its is possible to label MEP elements on Archicad or not?
If yes, HOW??
Thank you
Regards
4 REPLIES 4
David Maudlin
natmax:
Yes, same as other elements: select the MEP parts, then check the "Label Elements" in the Listing and Labeling panel (or the ID pane of the Info Box). Make sure the labels are on a visible layer to see them. Fore more information see: Placing Associative Labels.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thank you for your reply, but i miss place my question.
Yes i can activate and show the labels, but there is no label to show useful information for MEP elements, like real dimensions of the element, bottom or to elevation etc etc.
For example if i use the dimension label, it will always show 1.00x1.00x1.00 no matter the element section.
Hope now you can understand my question.
Thank you
regards
Max
David Maudlin
Max:
The MEP objects don't use the basic A, B, ZZYXZ parameters, so the Dimension Label cannot pick up the correct dimensions. See this thread for a different label that can do that: Labeling MEP Objects.
Thanks for adding the signature.
David
Thank you for the information.
Goto buy "Labeleverything".
Regards
Max
