MVO SETTINGS
abdullahten
Hey everyone
I have a question on MVO settings. I am trying to understand which setting affect my plaster line weight.I can easily change my coloumn thickness,  wall however I can not change thickness of plaster.
The thickness of the plaster line is determined by the pen chosen for that line in the composite structure settings. You can set various thicknesses for that chosen pen by changing the pen in the pen set and then saving various versions of the pen sets.
MVOs do not control the lines and thicknesses associated with various elements of composite profiles.
Lee Hankins
macOS Sequoia (15.1.1)
1 REPLY 1
Lee Hankins
