DGSketcher
Legend
MVOs
I would be interested to know roughly how many MVOs do you have in your projects?
I'm not looking for definitive answers as to how you are using them, just the number that you have in regular use.
I have 10 in my template which I use for one off houses.
16 Replies 16
Gerry Leonor
can i ask what the use of zone stamps are these days, now that you can tag them with labels?
are there things that the labels have difficulty in calling up in zones?
https://discord.gg/XGHjyvutt8
Lee Hankins
We find with the labels we would have to create multiple additional layers for all the different information we want to pull off for each different type of drawing. With the Zone Stamp linked to MVO's we can use a single Zone on a single layer and utilise the MVO to control the content of the stamp.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
JeffH
We currently have 18, broken out to follow suit with our Layer combinations & Graphic Override combinations.
It allows us some flexibility if someone needs to tweak something for a various reason, that we don't have those adjustments everywhere.
An example view would be set up with these settings
Layer Combination:     08 - Door & Window Plan
Model View Option:    08 - MVO - Doors & Windows
GO Combination:       08 - Door & Window Plan
I'm finding it to be helpful when Someone requests help due to issues, its easy to glance at the bottom of the screen and see if these settings are relatively accurate.
AC24 / AC26 / AC27
Win10
Marc H
Mine need review and work as well (several are carry-overs from older templates).  With that, I have:
(5) for modeling
(2) for 2D3D existing conditions plan docs
(2) for FMP (planning) docs
(4) for pre-design, schematics docs
(17) for DD/CDs, mainly around major doc types &/or scale
“The best thing about the future is that it comes one day at a time.” - Abraham Lincoln
AC28 USA on 16” 2019 MBP (2.4GHz i9 8-Core, 32GB DDR4, AMD Radeon Pro 5500M 8G GDDR5, 500GB SSD, T3s, Trackpad use) running Tahoe OS + extended w/ (2) 32" ASUS ProArt PAU32C (4K) Monitors
mthd
I am following this post to see what else I can learn with the application of MVO’s to improve the quality of my drawings. I am always looking for short cuts too.
Thank you for creating this post.
AC8.1 - AC29 ARM AUS + CI Tools
24C GPU 7.8TF 32GB RAM OS Sequoia.
DGSketcher
Legend
The aim was to simply gather some numbers to support a point I am making to GS. It is good to know it is helping in other ways.
mthd
I am looking forward to your wish list in this respect.
The localised version of Archicad need to be tailored to the conventions of our particular location or region in the world when it comes to MVO’s, attributes and complex dialogue boxes. If they can do that, then they can simplify the process.
Archicad is global as you all know and so they cater to all sorts of needs and standards. That’s why it gets messy and complicated unfortunately. Or you need a great deal of experience just to know where everything is in order to change simple minor things.
I think they could start with having windows and doors on separate layers instead of just being with the wall assembly that they are part of.
Have fun !
