Making AC 10, PDF and Vista all Play Nicely
Any help on enabling pdf printing from AC10 using Windows Vista would be very greatly appreciated. I received an email from Amyuni saying:
The version of the PDF Converter installed on your system is a special developer's version of our product which is registered to the software developer (ArchiCAD) and you are unfortunately not entitled to a free update or technical assistance.
When our product is used in a third party application, we can never be sure how it is implemented, so we direct customers using our products in a third party application to check any problem with their application provider.
However, since you are a licensed user of a product that uses our component we can offer a price discount on the Desktop Edition of the PDF Converter which is also compatible with Windows Vista.
http://www.amyuni.com/developer/
This is a standalone version of our product that will allow you to print from this application and from all other applications installed on your system.
**It will not be integrated into the ArchiCAD application**
Thanks for any help.
Steve Jepson
Forget the PDF coverters if they cause you trouble. Use Adobe Acrobat.
I never could get the pdf converter to work in 10.
That's because it was total garbage.
I used free converter: PDF995:
http://www.pdf995.com/
Worked a lot better.
But not perfect, test,test,test...
No pdf conversion problems in 12.
Bier
