2022-12-28 11:08 PM
I'm working on migrating a file from AC 25 to AC 26 and it's going well, except when I right click "Show all in 3D" or "Show selection in 3D", it's totally blank. I tried zooming to extents and nothing. I think it must be something in comparing the AC26 out-of-box version to the file I migrated but I'm not seeing any differences. I imagine it's likely something very simple, but I'm at a loss as to what it is.
Please let me know if there are some usual suspects I should be checking. Thanks!
2022-12-29 09:40 AM
Switch the 3D window to 'Vectorial' engine rather than 'Hardware Acceleration (used to be called OpenGL)' engine.
If the 3D shows, I would suspect a problem with Open GL.
Each new version of Archicad seems to require a slightly newer version of OpenGL.
You may be able to solve it with a driver update.
2022-12-29 11:57 PM
Thank you, Barry. I was finally able to get it going after realizing that I was still using an old custom workspace. Once I applied the standard AC 26 workspace, I started seeing the model again, so now just got to reset all my key commands.
