Model Structure Relocation
Hi guys,
Need help.. can anyone suggest a simple way of relocating the whole model itself. I've created a 3 storey model which eventually was ask to modify its setback dimension from 2 meters to 4 meters againsts the adjacent model structure. And how about rotating the whole structure as well..
Best Regards,
Jamers
3 Replies 3
vistasp
Mentor
Jamers, if you want to move the entire structure, you'll have to select it using the thick marquee which will cover all stories (the thin marquee only takes the current storey).
As to rotation, have a look at a recent thread here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=158153
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Eduardo Rolon
Don't forget to turn on and unlock ALL the Layers first.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks a lot ejrolon and vistasp.. i quite missed that thick marquee application! i've only tried using the thin one!
