Model View Option Combinations export to other file?
Can you export/import/save as preferences/whatever your Model View Option Combinations?
2 Replies 2
Hi Ignacio,
Yes. There is an option in the model view window to save it as xml file.
Then in the other file you select import and open the saved xml file.
Hahah and it is a pretty large button! Thanks very much.
