Modify capitalization of autotext <Orientation>
srdavids
Hi All,
I have about 65 interior elevations I'm trying to auto-populate onto sheets. What Id really like each elevation name to be is "ELEVATION NAME orientation". For example KITCHEN west, CLOSET south, etc. Is it possible to get the <Orientation> autotext to lowercase the first letter? As of now it's "KITCHEN West" and Id rather not have to modify each one individually. Thanks!
Phillip_Osborne
I've been having the same issue. Did you ever figure out a solution?
Unfortunately not - it seems the census is that it's not possible. Since the GS forums are often fairly useless, I posted elsewhere. Responses there said it's not possible.
Pedro Melo
I share your interest in enhancing text formatting capabilities within Archicad. To address this, I’ve proposed a wishlist item titled "Text Tool Capitalization Options (All Caps, Small Caps, etc.)", aiming to provide more versatile text formatting directly within the software.
Your support would be valuable:
👉 Text Tool Capitalization Wishlist
Setup info provided by author
