TMA_80
Multi column text
Is there an option ( or a workaround) to get a multi column-text ) ?
AC12_27 |Win11_64bit|
1 Solution
No option that I know of and the only work around I can think of is to use 3 separate text blocks - but of course they won't flow from one to the other.
Or maybe one long narrow text block that you can place multiple views of and crop on a layout - then the text may flow properly as you edit it.
Go to post
3 Replies 3
Scott Boyd Turner
As Barry suggested one long text box placed on sheet multiple times, I have used this approach successfully to deliver reports directly from Archicad without needing to use a page layout application
regards
Scott
Regards,
Scott
MSI Creator ZP16, i7-12700H, 32GB RAM, RTX 3070 8GB
TMA_80
Thank you ! The view is a nice workaround.
I wish , though, that Graphisoft may have a look to that as " nice addition" to an already powerful layout tool
