2007-05-20
03:06 AM
- last edited on
2023-05-30
10:08 AM
by
Rubia Torres
2008-03-27 02:07 AM
~/archiben wrote:Got it, thanks. I was trying to do it all from the master settings dialogue until realising from your comments that i need to use the print command from the file menu to actually tile it. I knew i was missing something simpleDjordje wrote:other way up
Set the small paper size ... and it will automatically tile.![]()
set the master/layout size to the size of layout you want (the larger size) and print/publish to whatever paper size you have (smaller) . . . it will tile . . .
~/archiben
2008-03-27 11:24 AM
Mark wrote:Yes, the only problem is if you want to print the tiled pages in an order different from the order the prointer prints it for you. No solution for that unfortunately.~/archiben wrote:Got it, thanks. I was trying to do it all from the master settings dialogue until realising from your comments that i need to use the print command from the file menu to actually tile it. I knew i was missing something simpleDjordje wrote:other way up
~/archiben
Thanks.
