My views are disapearing - Please Help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2013-10-09
09:46 PM
‎2023-05-26
04:36 PM
Rubia Torres
I am 100% sure i didn't delete it an if i had deleted it, why can I still see the views on the layout book.
Please help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-09 10:34 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-09 10:49 PM
Here is a image of what I mean
All the views on the page were create on the same worksheet
Its no where to be found in Project map or View Map
I have looked through the whole project and cant seem to locate it at all.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-10 12:26 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-10 12:50 AM
Ok so here is what I did:
1 - In Project Map I created a New Independent Detail (Under the Detail)
2 - Created the View Settings and storing options and named it "Engineer Retaining Wall Details 1:10"
3 - Dragged the "Engineer Retaining Wall Details 1:10" over into my View Map
4 - Started to draw ALL my engineer beam details together there, so that I can see how all the beams connect to one another an also to put them at the right FFL. (I know I should create each detail on their own Independent Detail but that's a working progress)
5 - I then go to my Layout Book an copy over the view "Engineer Retaining Wall Details 1:10" as many times as i need , as there are many details on this view
6 - Rename each view to represent what the view is showing
Also the detail i have highlighted in the image is just one of the details on the Engineer Retaining Wall Details 1:10 view that I can not open the source view.
the problem is that "Engineer Retaining Wall Details 1:10" view has completely despaired from the whole project, cant seem to locate it in either the "Project Map" or the "View Map"
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-10 05:03 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-10 09:18 PM
Michael wrote:Will give that a go, but how do I copy the detail? when I copy it, it just copies the view an also how do I explode the view into lines?
You could copy the drawing from the layout, create a new independent detail, paste the drawing in the detail, and then explode the detail back to lines. Not ideal, but at least you can get it back to something manipulable.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-10-10 10:06 PM
It worked!!!
thank you, its not ideal as you said but it works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-06 03:47 AM
And this time its my section, it has gone from the 'Project map' and 'View Map' yet it is still on my 'Layout book' and I can still move its view extent (move sub-element) but cant open source, says Update Ststus: Unavailable
Anyone know why this is happening, and has anyone else gotten this problem??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-12-06 05:15 AM
