NCS Wall Label 23
What controls the Text orientation in the Settings of the NCS Wall Label 23
If I use the Geometric Method: Associative the results are as shown below.
If I select the Geometric Method: Independent, the label is not available.
Any way to control the Text orientation
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
3 Replies 3
David Maudlin
Conrado:
Try Label Settings > Symbol Label > Label Orientation > Custom Angle.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks David.
Allways good to hear from you
David Maudlin
Conrado:
Thanks, glad I could help.
