You don't say what version of AC you have.
To get a clean drawing, you should be creating a 3D Document from your Axo view. Not only will you get vector linework, cut fills, etc., but you can annotate the drawing in the 3DD. (Right click in the 3D window to Create 3D Document.)
If you have an old version of AC prior to 3DD, then as Thomas suggests, you probably want a hidden line view with the Internal Engine, but you must render enough pixels to not get the jaggies/pixelation that you see. See the Rendering settings.
By default, the render will be at 72 ppi, which will look terrible - a resolution designed only for on-screen viewing. You need to set the total pixels to a a value based on at least 200 dpi if not 300 dpi. So, for a 10" x 10" image, you need 2,000 x 2,000 pixels (fax quality) to 3,000 x 3,000 pixels.
The 3D Document is a superior solution as it is vector based, not raster.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
