New and Existing - how to show "end" line when end to end
rob2218
see attached.
we need to indicate that "end" line condition to distinguish when "new" meets "existing".
I cannot change the justification of the wall planes either...they MUST have the same reference line (the framing skin).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
26 REPLIES 26
rob2218
YES....I've created a custom "renovation filter" option that allows me show "existing" as two single lines, no fill pattern in between and "new" walls as you see it, with all the composite and skins showing.
where do I access what you are suggesting?
sinceV6 wrote:
Hi Rob.
Are you using renovation filters to set up your model view? If you are, it is as simple as using the "Do not intersect" in the additional filter options for your new elements.
Hope that helps.
Best regards.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
but....I'm confused.
I do WANT the new walls (new elements) to indeed intersect but only with each other "NEW" elements, not with the "existing" elements.
if I switch that toggle?..........wont then ALL the new elements not intersect with each new elements? that's not what I'm looking for....I'm looking to simply have a "line" separate new from existing but have ALL existing intersect correctly within itself and have all NEW intersect and cleanup correctly amongst themselves...
sinceV6 wrote:
Hi Rob.
Hope that helps.
Best regards.
i>u
Edgewater, FL!
SOFTWARE VERSION:
sinceV6
sinceV6
sinceV6 wrote:
Hi Rob.
Hope that helps.
Best regards.
Nope. New elements will intersect with new elements, but not with existing ones.
Try it to see if it is what you are looking for. If it's not, just change it back. No harm done.
rob2218
yep...that did it!
thank you sooooooo very much.
i>u
Edgewater, FL!
SOFTWARE VERSION:
sinceV6 wrote:
Hi Rob.
Hope that helps.
Best regards.
Wow, I did not know about that option. Such a easy solution.
Sorry for all my "bad" recommendations.
I learned something new today.
rob2218
no worries Lasz....you've had way way more "good" suggestions than bad so not to worry.
I believe you are ahead of the curve on that one.
But yes, it appears you can have the renovation filter make "NEW" and "EXISTING" not clean up while all the while have walls that "ARE" indeed within their own renovation phasing clean up with each other..............thanks all.
i>u
Edgewater, FL!
SOFTWARE VERSION:
