2017-03-27
		11:25 AM
		2023-05-19
		03:52 PM
			Gordana Radonic
2017-03-27 02:15 PM
2017-03-27 02:32 PM
2017-03-27 05:35 PM
2017-03-28 08:26 AM
2017-03-28 02:45 PM
2021-07-08 02:55 PM
2021-07-09 02:33 AM
Thomas wrote:
Having the same issue.
Editing text of label, when tool activated and jumped int the textbox or labelbox doesn't work.
Adding text is possible, delete of mofify anything doesn't do anyhing..
Is the problem inside AC, or between the keyboard and the software ?
2021-07-09 08:39 AM
Barry wrote:I mean, of course I can enter in the textbox of a text or a label, but I can't edit the content.
So what you are saying is you can add new text or a label.
But you can't select an existing text or label?
Or you can select them but you can't edit the text (with the corresponding tool active)?
Is it happening in all files?
Have you tried re-starting Archicad (or maybe the entire machine if you do not do that often).
2021-07-09 08:48 AM
