Objects don't display correctly in plan
Pierpaolo
Hello community,
I have an issue with a file: I have imported the 3D mass from Rhino into an Archicad 27 file and the plan of the ground floor (0) doesn't display the elements imported (walls) at all, I wonder why. I attach the file in question.
Thanks for any help.
Pierpaolo
Operating system used: Windows 10
AC Edu 27 & 28 IT • Win 10 32 GB Ram • ASUS ROG Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz 2.81 GHz
David Maudlin
Pierpaolo:
It is a Display Order issue. Select the ground plane Object and Send to Back.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks!
Pierpaolo:
Good to know that worked for you, thanks for adding your signature.
David
Setup info provided by author
