2004-04-05
04:57 AM
2023-05-26
02:39 AM
Gordana Radonic
2004-04-26 08:20 PM
Eric wrote:Now the million dollar question is:
Some of our standard details are linked directly to the standard detail PLP file instead of placing them into the project file directly
2004-04-26 08:43 PM
2004-04-27 12:31 AM
Richard wrote:Richard what is the advantage of having one layer for each detail and ending up with 500 layers for 500 details vs. possibly one master layer of ArchiCad for all?
and then put each detail on a single layer. (e.g. Footing 1 = layer 01, Footing 2 = layer 02.)
Richard wrote:My question to you and Eric remains; how does one link these details in PM to the detail marker on the floor plan?
each of the PMKs will come in uniformly titled, with label, number, and scale.
2004-04-27 12:54 AM
Joseph wrote:Joseph:Richard wrote:Richard what is the advantage of having one layer for each detail and ending up with 500 layers for 500 details vs. possibly one master layer of ArchiCad for all?
and then put each detail on a single layer. (e.g. Footing 1 = layer 01, Footing 2 = layer 02.)Richard wrote:My question to you and Eric remains; how does one link these details in PM to the detail marker on the floor plan?
Thanks,
Joseph Harouni
2004-04-27 02:31 AM
2004-04-27 05:00 AM
2004-04-27 08:49 PM
Richard wrote:Richard,
You only need enough layers to cover the number of details on ONE story (say, 50?) I put each detail on one layer so that it can be easily displayed by itself, and zoomed with "Fit in Window".
2004-04-27 11:49 PM
Joseph wrote:First detail you draw on Layer 01 on a story with, say, eave details. Every other layer is turned off so you only see the first detail. Zoom to fit window and create a named View for that story and that custom layer set called whatever you want (e.g. Eave Detail with Gutter), then turn off layer 01 and turn on layer 02. Create a named View for that detail (e.g. Eave Detail - No gutter) Now you can view the details, either by highlighting the View Name in Navigator and looking at the Navigator Preview, or by Double-clicking the view name and actually looking at the individual details as they pop up.
Richard,
As I understand the name of the layers do not reflect the content of the detail itself; if so how can you view the detail you want base on layer naming of 01, 02,......49,50 for each detail?
Thanks,
Joseph
2004-04-28 01:44 AM
Richard wrote:Thanks Richard, finally I think got it.
2004-04-29 07:59 AM
Eric wrote:Hi Eric,
Of course a detail drawing cannot be linked to an external detail so that's why if you publish all of your details as modules you can then merge them into your project file and then link to them with a detail marker using the automatic detail numbering.
