Overall Dimension
dhnguyen
I have been trying to provide an overall dimension of a curved wall, but for some reason, ArchiCAD overrides my selection and shows me the 2'-6" dimension that I did not select. Please see attached for image.
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
Can you just select the dimension node you don't want and delete it?
dhnguyen
I see, thanks! it works now.
DNguyen
ArchiCAD 18- 25
