PDF file format missing in publisher, AC10
My Archicad 10 EDU doesn't show the PDF file format in the publisher "save files" method.
I tried this fix, but since I run Windows XP Home I do not have "Local Security policy" in Administrative Tools and the fix is useless.
Any other causes or other suggestions on how to solve this problem?
Did you install the Amyuni PDF printer driver?
The install is in the Archicad folder.
If you did not, this option is not available.
How stupid of me!
I had AC9 installed (and thus Amyuni PDF converter) when I installed AC10, after I made sure everything worked with 10, I removed AC9 and Amyuni along with it. (or it got removed automatically, not sure)
Anyway my fault, I'll take the blame.
