PDF printing text disappears
GFBArchitect
I am on ArchiCad 11 running on Windows 7 and XP. On both machines when saving to PDF the text will ocassionally disappear. It seems to happen mostly when it's a very large file. Any fixes?
Gayle Berkey, Architect
Littleton, CO
AC-20 USA, ACPI x64 PC, Win10 Pro, i9-9900K CPU @ 3.60GHz 3.60 GHz 32Gb ram
4 REPLIES 4
Try a different PDF print driver perhaps. Do you have Acrobat Pro?
GFBArchitect
We are using Acrobat Pro
Littleton, CO
So I guess you could try the Amyuni driver. It installs with ArchiCAD by default in Windows.
It could also be a font problem. Does it happen with all typefaces or just particular ones?
I've had this problem. I think it's an "out-of-memory" issue. Try different settings on the Adobe PDF printer: eg reducing compatability to earlier versions and compression etc. This has worked for me in the past.
