PM 9 Bug?
Steve Jepson
I cant seem to type in the boxes for adding additional drawing informaion
AFAIK, this is read-only information. Same behavior in earlier versions.
I'm a little confused as I would have thought that the information should be coiped from the linked pln file (or the pln file from which the pmk was generated), but the info is blank in PM 3.1 as well as 9.0 (pre-release) for me ... even though I minimally have my name and some other info in the source files. Not really something I've ever looked at, but a bit of a mystery nonetheless!
Interesting condition that I could not find right away. Since the condition is a dual one from AC to PM - The Drawing info tab is from AC project info. I found it by searching the latest help files and typing "Drawing Settings".
Hope it helps
Lew Bishop
P4 2.53 AC9 nVidia 440
__archiben
this information comes from the archiCAD PLN file (and always has!):
File>Project Info...
HTH
~/archiben
b e n _ f r o s t
