PM Master sheet with editable fields
Is there a way in PM 3.0 to create a master sheet with fields that could be changed in the individual layouts?
I know I could create auto text, but that’s limiting to the information used.
For example I would like to have a field for “area” where I would change the number in that field manually for each layout.
Also with the same rational, I would like to place a PMK in my master sheet, then on each layout be able to replace it with another PMK (while maintaining it’s settings ( i.e. scale, output colour..) instead of having to place it in the correct location with the right settings every time..
Thanks,
If this can’t be done than I guess I’m pasting this message into the wish list..
2 REPLIES 2
David Larrew
Unfortunately, you cannot currently do what you are asking in PlotMaker. You are limited to stay within the abilities of the Autotext feature - you could try to create a format for the Autotext to simulate what you want...
Same with your PMK - Master Layout request.
Looks like it goes to the wish list.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Djordje
Paste this into the wishlist, and don't forget the poll!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
