2012-04-25
01:07 PM
2023-05-26
12:05 AM
Gordana Radonic
2012-04-26 06:02 AM
2012-04-26 09:19 AM
NCornia wrote:Hi Nicholas,
Mats,
Here is our online help document about the process:http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
In the method you describe PMKs are saved for each drawing. This workflow does add an extra step though but can have some advantages as the document states. But this PMK method is more of a workflow control than a major speed optimization. You may be better off with two project files, one for the model and one for the layout book.
HTH
2012-04-26 04:06 PM
2012-06-05 08:40 AM
Erika wrote:
Do a google search for Big Buildings white paper+ Graphisoft and you'll find a link for a direct download. As Djordje reminded someone keep in mind that it was written [several] years ago for a different version.
You might also do a search here for pmk use. Duane Valencia, among others has a number of excellent posts on the topic.
2013-01-25 11:56 PM
2013-01-29 11:41 PM
ares997 wrote:It was a while so I hardly remember but I think I copied the whole project to a "layout"-pln which I pointed to the original file and deleted everything I didn't need. It worked in the end and no need for manual relinking of saved views.
Do you have to manually mange the markers? Is there a way to automatically connect markers from the layout book file to the model file or vice versa?
I am struggling with the idea of have to link 100 hundreds of saved views and then going through and checking the location of the source markers.
There must be a better way to break apart of complex large file in midway through construction documents and retain it's parametric aspects (with regards to markers and what not).
2013-01-29 11:41 PM
2014-09-22 03:29 AM
2016-01-05 01:54 AM
