Josh I don't know if there is such a thing but it would be pretty easy to make up. The size of the printable area would of course change with proposed print scale so you would have to decide ahead of time what scale and paper size you wanted and then draw a rectangle to suit.
What may be easier and more appropriate would be to take a copy of your title block out of Plotmaker Master for your proposed paper size, paste it into a blank story and stretch it by the proper scale factor. e.g. 48 times if you wanted 1/4" scale.
Then you could just ghost it when you wanted to check for fit.
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 27-5030 USA
2019 MacBook Pro (64GB w/ AMD Radeon Pro 5600M GPU)
