2018-03-08 01:54 PM - last edited on 2023-05-26 02:24 AM by Gordana Radonic
2018-03-08 03:05 PM
2018-03-08 04:34 PM
Erwin wrote:It's a simple black logo, hence the need for a fill. The rest is all text. Just seems strange that pen sets can show up differently depending on the fill type with no way of editing in the settings (from what I can see).
I never put anything other than simple black text on layouts and have that on ArchiCAD layer. Reason: you cannot save pen settings, layercombinations, overrides etc etc for layout view, so the option to make a mistake is very easy, especially with other people working on the project.
I do have worksheets that I save as a view and place on layouts. You can turn off the autotexting scale easily, in case that is an issue. Also means I can set up the view the way it needs to be and not worry about things showing up wrong.
2018-03-08 04:38 PM
2018-03-09 11:54 AM
Erwin wrote:So it turns out it comes out in PDF's perfectly fine even though it doesn't show up. Seems like a bug to me!
Even those things like the title block I put on a worksheet. Added benefit is that if you change the worksheet, it updates on all your layouts.
2018-03-29 09:16 AM
JGoode wrote:Hello JGoode,
