4 hours ago
Hi to all,
Do you know how can I delete a penset that is probably referenced somewhere and hence can't be removed because of it?
Many thanks!
Solved! Go to Solution.
3 hours ago
You can try deleting it from the attribute manager -
Options - element attributes - attribute manager
Pensets, and you should have the option to delete. Then go to changes, apply all and that should be it.
3 hours ago
