2025-01-10
10:47 AM
2025-01-13
04:59 AM
Hi to all,
Do you know how can I delete a penset that is probably referenced somewhere and hence can't be removed because of it?
Many thanks!
Solved! Go to Solution.
2025-01-10 11:08 AM
You can try deleting it from the attribute manager -
Options - element attributes - attribute manager
Pensets, and you should have the option to delete. Then go to changes, apply all and that should be it.
2025-01-10 11:08 AM
2025-01-11 07:04 AM
One more thing: If the pen set being used in the project file, you will be given the option to replace it with another, existing, pen set.
