Hammallu92
Pen set issue - Can't delete a penset
Hi to all,
Do you know how can I delete a penset that is probably referenced somewhere and hence can't be removed because of it?
Many thanks!
1 Solution
CosminF
You can try deleting it from the attribute manager -
Options - element attributes - attribute manager
Pensets, and you should have the option to delete. Then go to changes, apply all and that should be it.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Go to post
2 Replies 2
CosminF
vistasp
Mentor
One more thing: If the pen set being used in the project file, you will be given the option to replace it with another, existing, pen set.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
