Pen width for window fram in elevation?
Mats_Knutsson
Mentor
Where's the illusive setting? I can set pretty much anything else...!? /M
AC 25 SWE Full
1 REPLY 1
If I understand it correctly then it is the Upper Frame Width parameter.
Also make sure that the Uniform Frame Width parameter is not checked, otherwise you will not be able to set it to a value different from the Left/Right/Lower Frame Width values.
