Placing 3D Views to Layout w/ High Resolution
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2019-01-25
10:38 PM
2023-05-30
09:58 AM
Rubia Torres
When I have my 3D Window Setup correctly, I simply add the View to Layout. The image is of poor quality. When I open the images Setting and change the Resolution (dpi) , the image simply enlarges. I want the same size, but better quality without actually rendering my 3D view.
Please reference image below. As always, Thank You ArchiCAD community for the Time & Help. - Jakub
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-26 04:35 AM
I have recently completed a project where I have done what you are trying to do.
To achieve a higher resolution you will need float the 3D window and set its size to a larger size (for my project I set it to 5350 x 3000 pixels) this way you can save the 3D window as an image and place behind the 2d section and scale size to align.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-01-26 04:35 AM
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-11 10:33 PM
Once saved as an image, the image will not update. I am looking for a solution that updates with my work if there is one. I am also not sure what you mean by 'float'.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-12 01:43 AM
jakubgalczynski wrote:Manually resize the 3D window so it is not maximised (docked).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-12 05:07 AM
My workflow is that 3D images are published to overwrite old image then links are updated to load updated image into view. Not quite automatic but very quick and easy, current project where I am using this method takes about 2-3 minutes to update 4 No plans with textures shadows etc, 2 No elevations, and 1 No section of a 26 storey office tower with generic office fitout
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-12 05:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-12 05:20 AM
'Yes, I think you would have to stretch the ARCHICAD application window across multiple displays because in Windows applications no subwindow can be outside the boundaries of the main application window. (On MacOS they can be). So this is a Windows limitation which ARCHICAD has to adapt to. ' - LaszloNagy April 2016
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-12 06:34 AM
jakubgalczynski wrote:Sure you can.
I'm on Windows and unable to float in such a way that can expand my window infinitely. I am trying to get a window larger then my monitor, so that a Section can be saved with higher resolution.
Right click in the 3D window and choose the option to "Set window size".
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2019-02-24 02:57 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-19 11:44 AM
This does not work for me.
It basically means, that when I have only one monitor, I can only achieve resolution say full hd with 72dpi.
Because when I set the resolution to 5000x5000, I still have in layout same resolution , but the canvas is larger.
Solution for me is only to change dpi - that is not posible.
