Placing large 11x17 landcape MS Word tables in AC
Copy Paste method: Column width changes text breaks up with column
Make a PDF and copy paste: PDF is to lathe pastes text fuzzy
Is there a solution it worked better in AC 2.1 than in 9
__archiben
¡olé!
do it in excel...
use the 'camera' tool to capture the tables contents and formatting, then 'paste' into AC/PM. it will ask you if you want to paste it as an image or drawing elements: choose 'drawing elements' and you'll be able to edit lines and text as necessary . . .
don't give up on that mac yet adalbert . . !
~/archiben
b e n f r o s t
It must be from word because of formatting.
All what I wanted is to express my disgust to how AC evolved. The copy and paste from Word worked perfectly in 7 from, directly or from a pdf. now in 9 it does not.
I hope that the greed will do them in....
