SUBDIVIDING A POLYLINE IN EQUAL SEGMENTS
Fritz T
Does anyone out there know if it is possible to subdivide the area within a polyline - i.e. a closed drawing element or a fill area in 2d - into a predefined number of equal sized (in area) portions. The action therefore similar to the relative construction method in AC9 on the Control Box of providing pre-set snap points on a 2d line or other element defined either by equal sized sections, a fixed dimension, percentage or half?
I'm therefore trying to perform the same action, but within a defined 2d area.
AC 6, through 27
iMac 27' 3,1 GHz 6-Core Intel Core i5
500GB OS X12.7.3 Monterey
5 REPLIES 5
Petros Ioannou
If I understood correctly what you are asking,
I think its is impossible to achieve it since the combinations of dividing a polygon into equally area portions are infinite.
Could you post an example?
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
Fritz T
Petros
By polyline, (not polygon) I mean a 2d element with several sides, of which these are not necessarily parallel, but that explanation sounds too complicated.. Let me explain what I'm trying to do: I'm trying to subdivide a diagram of a street block into several equal sized portions, the number of which I would like to pre-determine. I'm currently doing it manually and then using the zone tool to auto-number the various sites. However I have to manually adjust each and continually tweak all to go through the exercise to get them equal sized, and then update zones, etc.
Was just wondering if someone knows of a workaround that automates the process?
AC 6, through 27
If you want to cut the polyline into polylines of equal length, you can find the overall length using the Elements Information Palette and highlighting hte second button. Then you need to do the math.
You could try to overlay sevral smaller fills (polygons) over you street block and turn on the option to show the polygon area in plan.
You would still have to tweak the size of the polygons manually but the area will update instantly on the screen as you stretch them - no need to update zones.
I don't think you will find anything to divide the area automatically.
Fritz T
Yes, that process does seem the best (and only) way.
I was hoping there might be an "automated surface subdivision tool".
Thanks for taking the time to reply.
AC 6, through 27
