2003-10-30
07:37 PM
2023-05-26
12:09 AM
Gordana Radonic
2003-11-09 01:14 AM
2003-12-01 04:50 PM
2003-12-01 05:21 PM
2003-12-01 05:26 PM
graphisoft wrote:it does work. but as they point out, the downside is that
It turned out that the library subtitution that worked for 7 works also for 8.1. That is: If ArchiCAD finds a library missing, it also checks a) the folder where the ArchiCAD execution file is wether the missing libraries are available in there b) the folder where the project to be opened is.
The workaround:
Place all the libraries that are needed for the project in the ArchiCAD 8.1 folder on the machine of the PlotMaker user. Make sure that the teamwork file is not saved with library references to the server machine, so that it would not find the libraries on the server, it would not load them from there. The drawback of this method is that users need to make sure that all the libraries are fresh on their machines, but for the bright side they will get fast library loading.
Unfortunately the library substitution does not work separately for each loadable library. If that worked you could store the project library beside the teamwork file on the server and the ArchiCAD 8.1 library in the ArchiCAD folder and Background ArchiCAD would automatically find the project library on the server, would load it via the network (would be always uptodate) and would load the ArchiCAD library from the clients machine.
