2005-07-2109:55 AM - last edited on 2023-05-3010:09 AM by Rubia Torres
2005-07-2109:55 AM
Is it possible to print/ output 'hairlines' option in Plotmaker. My AC files have various line weights attached, as you'd expect.
I understand you can manually change the Plotmaker line weights in the pen section (and this is what I have been doing), but I'm hoping there may be a tick box option or something that works across the board. Thanks.
I couldn't find that you had posted this in another forum, so I'll just answer it here.
To universally change the pens in Plotmaker go to Options > Preferences > Drawing Attributes and check the "Uniform Pens & Colors for Drawings and Book". Then just set the pens once and they'll be the same throughout.
