2006-07-20
04:35 AM
2023-05-19
10:24 PM
Gordana Radonic
2006-07-20 05:21 AM
2006-07-20 11:44 AM
2006-08-22 06:38 PM
TomWaltz wrote:Anyone have an idea why often 'the plot selected in navigator' option is not available for selection (in V10). I have highlighted the relevent layouts in the navigator as I would do in v9, but the option is subdued/unselectable.
There is no "Plot Entire Book" anymore, there is only "Plot Selected in Navigator".
2006-08-22 06:52 PM
Haneef wrote:It is available. Make sure you have a Layout as your current Window when you do it.TomWaltz wrote:Anyone have an idea why often 'the plot selected in navigator' option is not available for selection (in V10). I have highlighted the relevent layouts in the navigator as I would do in v9, but the option is subdued/unselectable.
thanks
Haneef
2006-08-29 12:07 AM
Haneef wrote:I had the same problem even I opened a loyoutTomWaltz wrote:Anyone have an idea why often 'the plot selected in navigator' option is not available for selection (in V10). I have highlighted the relevent layouts in the navigator as I would do in v9, but the option is subdued/unselectable.
thanks
Haneef
2006-10-06 08:33 PM
2006-10-09 08:52 AM
Steve wrote:It's called Publishing! It's an integral part of the ArchiCAD process and should be used instead of Printing & Plotting via the File menu, as part of a template system, in all cases IMHO.
Here's the trick. I just discovered it myself. Do everything just as LINK says to do, except when you want to plot, do not press the plot button in plot setup. Instead, push the PUBLISH button and it will plot the layout book for you. Confusing, but it works!
