Print the Navigator layout List ??
Hello there,
i like the navigator and its new possibilities in the Archicad Version 10 very much.
But is it possible to print or copy the full list of layouts in the navigator including the index plan numbers?
I want to have a register of all plans included in my Layoutbook.
Does anyone know a solution?
Thanks for your help!
Tobias Nippe
PlanBConcept
3 Replies 3
Link
Document>Project Indexes>Sheet Index. Then you can use the Index Settings... button to format it. It's quite limited, but at least gets you the list you need. Then you can place this index onto a layout.
Link.
Thanks a lot for the quick respone,
now i managed to create a layout list in the way i wanted it.
But how exactly can I add it to one of my layouts? I cant find a place it function.
Regards,
Tobias Nippe
Plan B Concept
Link
You'll need to drag it from your project map or view map into your layout book. You do this using your Organizer. This process is typical of placing many different items onto a layout, although there are different ways too, like draging and dropping directly from the navigator/organizer onto a layout, using the Drawing tool on a layout, etc.
Link.
