Problem: Publish to PDF fails. (from PLOTMAKER)
I try to publish some drawing to pdf.
It fails to write the file to disk. If i have many plots to a single pdf, it passes them all correctly, one by one, and at the last one fails to write it.
I wonder what it is.
Any clues?
2 Replies 2
Ben Odonnell
You don't happen to have an earlier saved version of the document open do you?
Cheers.
Ben
Ben O'Donnell
Architect and CTO at BIMobject®
Get your BIM objects from bimobject.com
No. Closed opened restarted... nothing. It wont publish to pdf from PLOTMAKER.
I forgot to mention that..
