Problem saving a plotmaker layout
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-01-30
05:13 PM
2023-05-26
02:36 AM
Gordana Radonic
2006-01-30
05:13 PM
I've spent some time today editing a plotmaker layout book. Now I want to save the work and I get a warning : [not enough memory to open the document].
I've tried saving as another file as well as tried opening another plotmaker file and then copying some layouts to the new layout book without any luck.
I can still work on and print the layouts, but cannot do any saving. I want to avoid rebooting and loosing any new work.':('
It's the first time I'm experiencing such a problem. I've also just updated to release 2172 Int Full version of Plotmaker 9 this week.
regards
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-01-31 07:42 PM
2006-01-31
07:42 PM
I would have this problem from time to time in PlotMaker 3.1. Never found a solution or work around. Always had to close PlotMaker without saving. The only suggestion that worked for me was to manually save often once back in that particular file.
Matt
Matt
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-02-01 05:43 AM
2006-02-01
05:43 AM
There is a problem with one or more of your drawings. This has come up before; you might search the archives I'm guessing about 6 months ago.
The only way to find which drawing(s) is causing the problem is to recreate the layout book and saving after each drawing. Tedious, but hopefully this will isolate the problem.
ARE you getting any error messages in ArchiCAD? This could clue you in to where the problem may stem from. Archicad can be forgiving and continue without crashing but by the time the info is saved out for plotmaker, a known memory hog, it may be too much. There may be something such as an inverted fill or slab that is problematic.
Another 'problem' originator could be an SEO.
HTH
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Mac OSX 10.11.1
AC5-18
Onuma System
