‎2005-06-18
09:43 PM
‎2025-02-10
03:59 PM
Aruzhan Ilaikova
‎2005-06-19 06:37 PM
‎2005-06-19 08:09 PM
‎2005-06-20 02:19 AM
southpaw wrote:Ah....USB, well that's a horse of another color & different than TCP/IP, location and network preferences. The message you were getting in your original message has to do with driver configuration in Plotmaker. Setting up a plotter in USB should be similar to printing.
The printer is connected directly to the computer, via USB. In Network Preferences (Mac), my location is Automatic. In Plotmaker, I entered the IP address listed in my Network preferences. Plotmaker didn't seem to be able to connect with the compuer. Then I entered the router number instead. Still didn't work.
southpaw wrote:The specs are printed out directly from the HP plotter by pressing a button sequence on the plotter itself. Check with instructions on how to print out a spec sheet. HP's been doin it this way for decades. The address should look something like 192.0.0.192 or similar. However, in using USB, the HP110 may show up differently.
I would print a test/spec from my plotter, but I can't even get it to print at all from Plotmaker.
southpaw wrote:Normally the port number on a direct connection to a Mac is 9100. However, since you're working thru USB, you may really be printing. I just checked Printer Setup in OSX-System Preferences and I didn't see a driver for the HP 110 listed so you may have to go to the HP site and download an up-to-date driver.
Which one is correct? Also, what would be my port number?
‎2005-06-20 05:34 PM
‎2005-06-20 09:16 PM
‎2005-06-21 02:54 AM
‎2005-06-21 06:52 PM
‎2005-06-22 03:47 AM
‎2005-06-22 08:26 AM
