2006-11-0306:02 PM - last edited on 2023-05-2612:14 AM by Gordana Radonic
2006-11-0306:02 PM
Hi all, I am having a small problem. I have used ArchiCad for about 3 years now so you would think that would not continue to have trivial problems, but that's my luck.
In V10 I am trying to publish my documentation into DWG. format to pass to a draftsman to finish. I go through the whole setup and select my view sets i want to publish, change format, set my translator, and just publish the set. Now, it will publish all three floors of my homes reflective ceiling plan, the first floor of the actual dimensioned docs. but will fail @ that roof plan, second floor plan and foundation plan. CLUELESS......
The ArchiCad fault message reads "ArchiCad unable to generate". Could somebody tell me what i am doing wrong? Thank you so much. This is my farewell task for my current company so if i could get this fixed it would help me tie up the loose ends pending my departure.
