mkopecky-
is there any perceptable difference between your problems when updating a local file as opposed to a networked one?
moving your file locally from a server will not necessarily change the file path to the
libraries
if they are on a server, and therefore not really help with BGarchicad's file loading time if you have big/lots of libraries stored on a server.
also - archicad/BGarchicad/plotmaker all have problems if, on a mac network, there has been some interruption to the file path, i.e. network going down, disconnecting then reconnecting to servers. . . when i have had the 'error reading file: <>.pmk' message in the past, it has usually been something to do with this.
you could try quitting archicad/BGarchicad/plotmaker, then, ensuring that you are connected to the necessary servers, try again.
if that fails, go to "Drawing Usage", select
all of your drawings and relink them back to the orginial file, (or your local copy if that's what you are doing to help speed things up).
hth
~/archiben
ps - where is "Work"? sounds like a place i know well!
b e n f r o s t
