Learn more
dhnguyen
Project Origin has changed
I made a copy of the original file to and worked in the copied file.
I wanted to bring some walls from the original file into my newly copied file and noticed that the walls don't land on the same spot when I Paste to Original Location.
This has happened in the past too. How do I fix this from happening again?
Also where do I go to check the file's original coordinate?
DNguyen
ArchiCAD 18- 25
(expert in AutoCAD, novice in ArchiCAD)
0 Replies 0
