Published DWF have dashed lines
I have created DWF files both within Archicad and Plotmaker. For some reason all of the continuous lines appear as dashed and any lines that were dashed in Archicad become continuous in the DWF file. I've attached the file. Any suggestions would be greatly appreciated.
I'm using Archicad 9.0 (hotfix 3), Windows XP
3 Replies 3
Steve Jepson
I have the same problem
This is an old issue.
Richard
AC26 (since AC6.0), Win10
__archiben
there was an issue i had a few years ago with version 8 that did this with scale-sensitive lines . . . the scale-sensitivity wasn't honoured and they all came out appearing solid.
i checked it quite extensively during the archiCAD 9 beta test and thought that this was resolved . . . report it to your local GS tech support people and give them the file. let's hope it gets fixed next time around . . .
~/archiben
b e n _ f r o s t
