Publishing problems
I've been trying to use publisher to set up final plot files.
(14 sheets)
I have my publisher set set up in navigator, all my plot wishes,
including save the files and where to save them. I want to save the entire set so when I need to plot another set, I won't have to open archicad,
I'll just send them to the plotter with a print utility program.
If I choose to publish the entire set, (with save) it seems to publish them with the same name and just overwrite the same file. I was hoping that this one file might have all 14 plots in it but it only plots one of the 14 sheets. I tried selecting all the items from navigator and that did not work either.
I have had to resort to publishing each individual sheet (selected item)
one after the other (slow).
Am I missing something here? Or is this a short coming of publisher?
I'm running archicad 10, windows xp pro, dual opterons, 2 gig meg,
nvidia 3400?, and a hewlett packard design jet 500 (next time I think I will buy a different make of plotter, lots of problems)
Thanks,
Jack
If I publish the selected items or the set and send it to the plotter,
it works fine.
Laura Yanoviak
In what format are you "saving" files from Publisher?
Link
In the Navigator/Organizer's Plot Setup, hit the Select... button in the Spool Folder area. In the Plot Settings, select Spool Folder in the Destination area.
Link.
