‎2006-05-05
12:01 AM
‎2025-02-07
02:43 PM
Aruzhan Ilaikova
‎2006-05-05 04:30 AM
rob wrote:No way of changing the lines that I know of.
This has annoyed me for a while. Is there a way to improve the quality of 2D lines in archicad and in particular their ends and junctions. When I look at my friends prints from autoCAD the quality and crispness of the lines is far better than mine from ArchiCAD. We use the same plotter and im aware of line weights etc. so im not talking about that but more the fact that if I have a thick line of say 0.5 or larger you can see that the end of the line is rounded and not square like my friends. This causes problems when thick lines meet thinner lines and actually protrude past them slightly due to the rounded end. I don't use plotmaker - does that help with line quality? Im using ArchiCAD 9.
I hope people know what im talking about! - and there is an option to get crisp lines with square line ends!
Thanks, Rob
‎2006-05-05 09:08 AM
‎2006-05-05 11:01 AM
‎2006-05-05 01:36 PM
‎2006-05-05 02:12 PM
Petros wrote:There is also an old wish about that somewhere.
This issue was also discussed here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=8568&postdays=0&postorder=asc&&start=0
Petros
‎2006-05-05 02:40 PM
‎2006-05-05 02:56 PM
‎2006-05-05 03:01 PM
‎2006-05-05 03:09 PM
Petros wrote:Maybe. First time I heard about that is probably 10 years ago (my reseller). As you know, GS developers rarely answer why they cannot achieve something. But I don't want to contradict Djordje about how hard they work
You don't need this for every line width.
Up to ,35mm the line can be placed on the axis.
It is thicker lines that need this adjustment and these are needed for section elements. Maybe an enchancment to the BoldCutLines display option would be enough?
Petros
