2016-05-06
01:32 AM
2023-05-19
03:53 PM
Gordana Radonic
2016-05-06 02:55 AM
4thorns wrote:Not that I am aware of.
1: I am wondering if there is a way to exit a text box using the Enter command without using the ctrl key. I'd like to be able to toggle back and forth from Enter key = exit box and Enter key = next text line.
2016-05-06 03:58 PM
4thorns wrote:On Mac, a triple-click will select all the text in a paragraph (between returns). Select All (Command-A) selects all the text including returns. Does this work in Windows?
2: Is there a way to have Archicad select all the text in a text block when I activate it? Either with a double click or a single click when the text box is selected. I am using ctrl/a after I enter the text box to select all the text.
2016-05-06 04:27 PM
David wrote:Yes, it works the same way on Windows.
2016-05-10 10:46 PM
