ROTATE DETAIL BUBBLE
Llian
How do I rotate the detail bubble to a specific element? Here is an example where I want to bubble the kitchen cabinet at the same angle as the kitchen cabinet layout.
Lilian Seow LEED AP | cSBA | CAPM | PMP
AC 29 USA FULL | Windows 11 Enterprise i5 3.10GHz | Archicad-user since 1994!
Llian
Actually I found the detail without boundary to be cleaner than having the boundary.
For curiosity, I still want to hear from the community if there is an angled boundary.
Eduardo Rolon
Depends on the Marker you use. Check that it has Clipping Polygon as boundary.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Llian
Thanks… I found it in AC20 version that I can have a clip polygon..awesome!
