Red Lines with Archicad
Hi! wich one is the best way to do mark-up (red Lines) in archicad in team work project?
I watch this movie:
http://www.youtube.com/watch?v=erQezDVwYjI
and I don't undesrtood how to import the red lines in archicad.
Thanks
Happy Thanksgiven
3 Replies 3
NCornia
Graphisoft Alumni
Graphisoft Alumni
Giuseppe,
Here is an excellent resource to answer all of your questions about Mark-up in Teamwork. Download and skip to Chapter 7: http://www.graphisoft.com/education/training_guides/?version=15&module=COL2&lang=en
To import the red lines see graphic below.
Hope this helps.
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
After you do the redlining in Reviewer you save them. Those redlinings will be saved in a DWF file.
Then at 5:05 in the video you can see that he chooses in the Mark-Up Palette to import redlines from a DWF file. This is when you have to specify the DWF file you saved earlier in the Reviewer and the redlines will be imported into ArchiCAD as Mark-Up Entries.
Edit: Nicholas just beat me to it.
Thank you so much I will follow the tutorial movie:
Happy! Thanksgiven
